Hi there.Re: Dt65 compression
Doesn't sound like crank seals. Assuming that your carbs are spotless, including the three tiny holes in the top of the bore near the throttle plate, have you tested and properly adjusted the throttle position switch on the middle carb? If you're not sure, send me a PM and I'll send you the procedure.
