DT 65 remove drive shaft bearing housing
rdxgator
I have removed the lower unit but need to replace the Drive Shaft Bearing Housing "item 11 below". Something is holding it (feels spring loaded). The Drive Shafte and Shift linkage are still in.
lunchman3815
Re: DT 65 remove drive shaft bearing housing
Get yourself a manual from seloc and it explains exactly how to do it. It requires a little mechanical apptitude but you can do it.
