dry plug...
mrc
1970 85hp V4. Idles rough, seems to be only running on 3 Cyl until 3Krpm. Then runs<br />great. <br /><br />Cyl 1,2,3 plug damp when removed. Cylinder 4 plug is dry. Surface gap plugs. Good <br />spark on all 4.<br /><br />Compression is 115psi across the board.<br /><br />Engine runs worse with #4 plug out and grounded.<br /><br />Point gap set wider than spec cause it runs much better that way. About 2 clicks<br />(indexed screw) beyond .01<br /><br />#4 plug is not cleaned (as in water leak) just dry.<br /><br />I've pulled the low speed idle screws, cleaned em, sprayed carb cleaner<br />in the hole, and reset low speed idle. Plug still dry.<br /><br />Carb rebuild kit is on the way. Also new high speed jets are ordered.<br /><br />Am I correct in assuming dry plug == lean?<br /><br />I worry about running the points too far open, what am I risking?<br /><br />Thanks for your time,<br />Mike
Greg Lawrence
Re: dry plug...
probly that carb? spray premix into that carb and see if it comes out wet on the other end? yeah dry might mean leano meano.
steelespike
Re: dry plug...
Other things remaining unchanged you advance<br />the timing when you open the gap.You also shorten the time the points are closed which would tend to lower the voltage build up in the coil.<br /> How much ???? Search me.Timing and Syncronization<br />are 2 things you need to check. Hope you are<br />working with a manual.
mrc
Re: dry plug...
Yep, have Seloc, and OMC original service manual and parts list. Find that both of<br />the manuals are useful. <br /><br />The puzzle with the point gap is that it has such a large effect on Idle speed behavior.<br />Frankly I'm just not smart enough to come up with a reasonable explanation of why.<br />I'ts not just the advance as that is basically all the throttle does for the first part of it's<br />throw, and one would expect the normal point gap to smooth out to the current point<br />gaps performance at a given RPM. Doesn't happen, rough all the way to 3Krpm. <br /><br />If I was somehow helping a weak amplifier by leaving the points open longer, I wouldn't<br />expect to see troubles at low RPM, only high. <br /><br />As far as misting premix into carb it makes me nervous :) , but I'll try it.<br /><br />Mike
sloopy
Re: dry plug...
is there alot of carbon build up on the pistons?
