Dry Gas Usage
ta400man
I did a search on Dry Gas and I did not much.<br /><br />I know that Dry Gas makes your engine run a little hotter. <br /><br />I know you can put a water separator on the fuel line.<br /><br />Do people just no like Dry Gas?<br /><br />I was thinking of running a can dry gas everyother tank? <br /><br />What do people think? Good, Bad or Indifferent.<br /><br />Thanks,<br />Shawn
tommays
Re: Dry Gas Usage
The problem is that things like dry gas make it hard for the water separator filter to work <br /><br />It changes nice water into a chemcial mix that can get caried right past the filter and into the carb<br /><br />tommays
mkast
Re: Dry Gas Usage
Seeing as how dry gas is ethanol, most areas now have to add 10% to pump gas, why bother?
