Need a little help on which direction to go! I have an 1983 open bow sportcraft with 120hp 2.5 mercruiser with 2 barrel Rochester carburetor. It's running rich and will foul the plugs after being on the water for a few hours, then hesitates on acceleration. I believe the hesitation is due to misfire on plugs.I have installed a new fuel pump, rebuilt the carb, new autolite plugs 145, electronic ignition conversion kit with 40volt coil and 12 volt power. Serial #6324320. Any help would be great. Still have to get compression test kit and proper hook ups to check fuel pump pressure. Also set mixture screw 1 1/2 turn back.
