trim question to Mr. Mariner
Mr. Mariner or any one familiar with A1G2 trim problems.
I have a 1992 VIP 18'-3" fish and ski-mercruiser 4.3L Alpha1 gen2 PowerTrim XD.
I have similar problem-I wanted to be sure I understood your thread from July 12, about cleaning the armature-so you concluded that the dirty armature inside the solenoid was the culprit?-just asking.
Basicaly the trim up and trim down and trailer swich all click-but nothing happens.
I'm new to this-sorry for the dumb questions-but-Is it difficult to remove the entire solenoid aassembly so that it can be
worked on outside of the boat?. I don't see how any serious detailed work could be done on it while attached in engine compartment-very cramped area in my boat. I have cleaned the 2 or 3 main large stud connections(up and down) that I can get to inside the compartment. There are many other connections mentioned that I would like to get to. -Or -do you remove a single up or down solenoid-I can't tell if these are removable componnets of an assembly-or all one unit, in it's current location within the compartment. Also-not eaxactly where to locate trim limiter switch assembly-I have the troubleshooting chart-but see no device that resemble this on my boat-I'm sure I am looking in the wrong place-any chance it is behind the throttle lever assembly, or on the outdrive itself, attached to the trim motor somewhere?. The 20A fuse at the solenoid is good, I get/read 13volts when I jump from the center post to either of the solenoids-but nothing from solinoid to solinoid. I can disconnect the the blue/up wire from it's terminal, and connect it only to the green/down terminal, then hit the down trim button, and the outdrive raises all the way. I have pushed the 50A circuit breaker reset button-nothing happens, it was not popped out anyway.
any help appreciated.-thank you RV
