turtles11756
- Dec 5, 2007
- 260
hello, the O ring on top of the drive shaft broke apart during my many attemps to bring gear case back up to power head after replacing the impeller which was in pieces. can i get a new one here on i-boats parts or where else might i find it ? and is it normal for the drive shaft to just pull out of the prop shaft ? thanks I'm still learning and everything is a first to me but once i get the lower unit back up and torque down on the flywheel nut this old Johnson should fire up after 27 years in the garage
