OK dipstick!Sometimes I guess you just have to take a breather.Crashed out at midnight last night,woke up at 5 AM with boat on the brain.I just realized how I lost my 3/4" adjustment on the motor mounts.When replacing the transom assembly,the inner plate does not have holes for the studs,IT HAS SLOTS.I knew there had to be a reason.Obviously,I installed the new one LOWER than what the old one was set at.I haven't gone out to look at the old ones "washer pattern"yet(just got my guys off to work)but,I am already 1000% sure this is what I did.HAS TO BE.Grrr,now what to do.Pluck the motor back out and re-adjust the inner transom plate or just put some spacers in and call it done?I'm thinking spacers should be fine.Maybe compare where the studs were seated on the old one to where they are on the new one and thickness of spacers can be UP TO as much as the difference.Any Input?Don?Would you call this good?Like I said,haven't checked yet but,I'm sure thats what I did.
