250Gimp
- Jul 13, 2007
- 145
Hi All
I am having some trouble with my lower unit oil reservoir.
I have some theories, but I will set the stage first....
2006 Maxum 1800 SR3
2006 4.3L MPI, Alpha 1 Gen 2
-I followed the service manual for draining and refilling the lower unit
-Drained and cleaned the reservoir, I used a bit of gas and had it coming out of the bottom of the reservoir where the line connects.
-I blew out the line (by mouth) from the reservoir to the quick connect mid-way to the transom.
-Cleaned out any excess gas and refilled reservoir.
Result.....no oil to lower unit vent, or even to the disconnect mid way!
The reservoir is in a really tight area and the line that comes out the bottom of the reservoir rises up a bit and then runs along the valve cover before dropping down to the transom at the back.
I am suspecting that I need to run the drive, hopefully on the muffs, to create some suction in the line and draw the oil down to fill the line.
I am no mechanic, and am not sure if I have the right idea.
If I am way off base, please correct me!!
Sorry about the long post, but this was my first winter with the boat, and I want to make sure it is all ship shape before going out on the water.
This is also my first I/O.
Thanks for the help!
Cheers
2006 Maxum 1800 SR3
Cheers
