I have a 1993 Bayliner Capri, with Alpha One Gen2 drive. Recently I noticed drive oil leaking from the water inlets (boat was stored with drive in down position). I have researched on this forum and other various places. I've come to the conclusion that I have a leaky drive shaft seal (under water pump), or a leaky shift shaft seal - or both. I won't get into the drive until this weekend, then I'll know for sure what I've got after a pressure test. Operating under the assumption that I end up replacing both of those seals, I have the following question. What special tools are required to R&R the drive shaft seal and the shift shaft seal? I have a good selection of typical tools as I have done alot of mechanic'ing over the years. I've had the drive off several times over the last 9 years that I've owned the boat, but I have never replaced these seals. Thank you.
