lilboatsman
- Apr 7, 2007
- 58
Search results didn't help to much. I just replaced the 5.7 motor in my 1989 Arriva. I aligned the motor, and installed the MC-1 drive (pre-alpha) and it likes going forward, but not reverse. In reverse I here some sounds that indicate that it's trying, but failing.
Now I'm not 100% sure this drive is even good, but I figure there are some things to investigate before I pull the drive. How can I check the shift linkage to see if it's doing it's job? Pull the linkage to the drive and try it manually?
