draining oil
mctigueak
Purchased Yamaha F150TLR, noticed oil was over filled. I wanted correct the oil level. Manual says "Remove drain plug then open fill cap to vent" . When I removed drain plug, the oil streamed out. There was an open vent somewhere with the fill cap and dip stick in place. Is this normal?
Georgesalmon
Normal, there is enough volume in the oil sump to allow the oil to run out. Not like a lower unit and much thinner oil to boot.
