draining i/o
wdaws01
Do you all believe it necasary (spell check that)to drain the water from the motor eack time. I flush it out very well but see that the motor has drains in the risers. its an omc 4.3 6cyl w/ cobra(a problem in its self). Should i keep these drained after every trip or what?
boatingfool
Re: draining i/o
Fresh or salt water??<br /><br />Fresh water - no.<br /><br />Salt water - not a bad idea.(corrosion)<br /><br />The main reason for draining is to protect the engine block from damage when it gets below freezing.<br /><br />I dont know anyone who runs in fresh water who drains thier engine in the summer.
