Re: DRAINING AND CLEANING FUEL TANK
Specks,<br /><br />You'll never get it all out unless you can remove the tank. Best to just pump out as much as you can with a pump certified for fuel. These are available at most marine stores. Some attach to a drill motor. They're not that expensive.<br /><br />If you do not have a fuel filter/water seperator, get one. Keep the spin on filters changed and you'll be OK.
