Drain plug anti seize
Onexl85
Recently had to chisel out my drain plug on an alpha.1 gen 2, wondering if anyone uses any kind of anti seize on the threads. Was thinking about using a little quicksilver perfect seal
how long was the plug in place?
did you try an impact driver before the chisel? would have been my first suggestion.
Onexl85
Put the plug in last April, didn't really use a chisel. But after slapping multiple screwdrivers one was a snap on so I don't use garbage tools I wound up drilling it and useing my pneumatic impact driver to get it out
Never had a drainplug that wouldn't come out with an impact driver.
Has nothing to do with the brand of screw drivers
alldodge
Never used anti-seize and haven't had much trouble getting it out. Most the time I use a 2 foot long screw driver because it has the largest blade tip. If there was an issue my next thing would be the impact screw driver also
never seize on the threads wont help either as the threads are already on the oil side of the sealing o-ring.
Alumarine
As others have said an impact driver is the way to go to remove stubborn drain plugs etc.
Also, those plugs don't have to be that tight.
Bt Doctur
The largest screwdriver ground to fit tightly
A hand inpact tool with a bit that fits tightly
Weld a SS bolt to it.
Oshkosh1
Ensign
Drain plugs and spin on filters...probably the two most needlessly over tightened fittings on any car, truck, boat and virtually every other engine. Once the plug is snug, just a bit more is all it takes. Same goes for filters...once the gasket touches the surface, 1/4 turn more is all it needs. If you can't remove either easily by hand...you've screwed up.
Let the threads and gaskets do their job. No need to hammer either on...
fishrdan
Not much need for anti-seize as the plug is lubed up pretty well.
I have a big ol' cheap Harbor Freight screwdriver that fits the drain plug perfectly, it also has a 1/2" (13mm?) hex fitting right before the handle. Getting drain plugs out is easy/cheesy as a wrench on the screw driver gives the leverage needed to break it free, easily.
I may have ground the tip down years ago (???) so it fit the drain plug perfectly, but removing drain plugs is the only thing I use it for...
Grub54891
If you use new gaskets, or O-rings every time they come out easy. I know the gasket type get stuck when they lose their " crush". O-rings are just a good thing to replace to prevent water leakage.
