Hello Gentlemen,<br /><br />I finally got it all together and have been useing my new boat and motor thanks to many of you in your assistance in purchasing and in the setting of it all up.<br /><br />I have a 16 foot alum. Princecraft Starfish and a 25 hp Mariner 4-stroke short shaft <br />(15"). Thanks to JB for sugestion on 4-stroke.<br /><br />I have a small problem. The motor bracket is a biggie. There is a zinc bar that runs along the bottom of the bracket and it just covers an edge of the drain hole. The plug will therefor only go part way in and not far enough in that I am satisfied that it may not fall or be knocked out. <br /><br />I would simply raise the motor a hair except that it is bolted on and I did not anticipate this problem before I drilled the holes.<br /><br />I am wondering if I should remove the zinc or cut it to make room or what. It obviously has a purpose but the boat is only in the water on the weekends for 3 months of the year. I will have to cut a good deal of it away all but severing it if I do so. Has anyone encountered a similar problem? <br /><br />Thanks
