Hello all. Afer re-installing outdrive this year, I'm having issue with not being able to screw in brass fitting on shift cable far enough to line up with the hole on the shift bell. I have the groove in the shift cable firmly in the 'claw/clamp' but the thread portion end of the shift cable seems to be sticking out close to a half inch too far for brass fitting to line up with hole in bell while in neutral. I was able to get it in there with it kind of in a bind but I could tell it wasn't shifting correctly while out on the water. The cable itself is actually sliding smoothly back and forth so can't understand how it couldn't line up unless something is 'stretched' somewhere which seems unlikely to me. It went right back into place last year when I replaced outdrive. Any ideas on what the issue could be?
