Scanman1973
Thread starter- Joined
- Jun 26, 2011
- 22
Hi All,
Just making sure I have this right on my 2000 DP-E (1.68), the props are aluminum A3 set:
-Notched thrust washer
-Forward prop
-Nut
-Smooth thrust washer
-Aft prop
-Plastic washer
-Cone
I ask because there looks like more space between the forward prop and the zinc and between the two props than I remember. This is my second year with the boat, so my mind may be playing tricks on me. The other reason I ask is that the boat originally came with B4 props and when I removed the props only the notched thrust washer was installed, I got the smooth thrust washer when I bought a set of C2 props.
So, is this the correct sequence, and why was there no smooth thrust washer on the original set of props (B4)?
Thank you,
Andy
P.S. I did do a search, but could not find the answer (probably my fault).
-Forward prop
-Nut
-Aft prop
-Plastic washer
-Cone
Thank you,
Andy
