Dorsett Farallon
barry6743
Does anyone know what the Max rated HP might be for a 20'5" 1959 Dorsett Farallon model Cabin Cruiser?
bayman
Re: Dorsett Farallon
That is a very difficult one as there are very few of these boats out there. You might have to use the USCG formula to figure it out.
Do you have any Known History on the hull,..???.....<br /><br />How about a Picture,..??..... I haven't a Clue as to What your boat is....
barry6743
I have some pictures but this site does not allow direct attachment to replys or questions. This boat also has a Flying Bridge attached which does not show in any of the pictures I have found. I am considering adding a completly rebuilt 120HP Force motor and am wondering if it might be too much?
tomcatcain
Barry6743,I have a 1998 trophy 19 ft cc with a 120 force on it. The 120 does not have enough power for my boat.Even running a prop with 2 " less pitch than I need.......Still slow to plan off.Too slow to plan in rough water..
barry6743
I will only be using it in the lower part of the Sacramento River (current 5-10 knots )and I don't usually travel more than 5-10 miles to my fishing spots and I have a 23deg pitch prop to push it along with although a 17-19 would probably be better.
tomcatcain
Running a 17 pitch on mine,turning 300 to 400 rpm over wot for the 120 motor.
barry6743
The guy that owned the motor I'm buying felt that he wasn't getting enough speed so he opted for the higher pitch prop. I have one brand new and another just like it on the motor. I'd like to swap the new one for one with 17-19 pitch.
tomcatcain
I need a 19 pitch on mine,but that would kill my hole shot,two slow planing with the 17.Bought a set of smart tabs,but have not installed them yet.Hope they will help my hole shot,then maybe a 19 pitch which put my rpms where they need to be at wot....
barry6743
My boat already has a pair of cavitation plates mounted on either side of the stern which should help it plane faster but if I use the 23 pitch prop it may be a moot point.
