I have a 1999 B3 with 7.4 liter, serial OL440701 and 2:1 ratio. I've owned it since it had 93 hours on it and it now has 235 hours. I took it to a different shop for u-joint, gimbal lube and shift cable assy. The shift cable bellow was cracked, leaking some water and toasted the cable. It's always been kind of stiff shifter, but no growling or chattering. In past boats, I've had Merc #1, Alpha, Volvo and OMC in the past, most were much more clunkier than the B3. I just figured that's the way B3's should be. The shop mentioned it SHOULD shift a whole heck of alot easier than it does. In the upper unit, he changed everything but the clutch, shaft and gears. This made it a little better and liveable. He also said Merc came up with a $1000-1300 gear upgrade kit to solve this problem in older B3's like mine. The kit has new gears and clutch? I was a bit skeptical until I drove a drove someone else' boat with a 2001 B3 drive!!!s OMG! It was so much smoother in and out of gear than mine. <br /><br />I'm giving the gear upgrade kit some serious thought. Don S. or anyone else, what can you tell me about this? I see ebasicpower makes mention of the merc svc bulletin in their catalogue, but no specifics. Anyone here have this done to their B3? Was it worth it? Let me know...
