doesn't throttle up in gear
razzor
1992 mercury, 75 horse, serial #0d165408.
Idles good, takes off good, runs good,as I increase throttle the rpms go up but the boat doesn't increase in speed,
I'v replaced the prop hub and checked for proper prop size,
If I squeeze the bulb 5 or 6 times and hold it tight I will get just a little bit of gas coming out from behind the fuel pump and the block. Also, if I squeeze the bulb while I'm increasing the throttle the boat seems to want to take off finally, What is all this trying to tell me? My 1st O/B.
compression is good, 135-128-125.
mix is at 50-1
Thanks a bunch everyone in advance, razzor
tashasdaddy
Re: doesn't throttle up in gear
if you leaking gas, between the fuel pump and block, you need to rebuild first. and eliminate that problem, if it leaks gas it sucks air.
razzor
Thanks dude, I will get started on that right now.
Razzor
gungalunge
is your propeller under the boat right ??? meaning the shaft lenght right
