Hi all,
I want to add a 20 gal bait tank in front of the center console. How does your pluming run especially the drain or overflow line run? below deck? 20 gal @ 7 lbs = 140 lbs. Is this to heavy for the front bow of the 18 CC?
Re: Does your boat has a bait tank infront of the 18 CC console
Sorry I was a bit busy hear are the photos did not clean under the CC yet!!! but you can see the connection. in the rear left the intake with a screen and the drain on the right
If you look at the second photo at the bottom right you will see the drain line and it has a 5/8" plug on the inside of the tank and I think it drains at the rear next to the pickup line photo #1 I think.but I don't know if it is connected to the over flow I have to see it in action but most likely it is connected to it and that will act as a vent when you drain it like the bathtub I can not see under the floor and it is freezing out there I can not test it sorry I have not used it yet the boat is new to me have you used yours and how do you like it what motor you have?
