Does yamaha have a prop that fit an alpha l genll outdrive?
svb165
im having difficulty finding the right specs to see for myself.
Chris1956
Generally, the modular props will fit most makes, with the correct hub kit and hub size. My V6 Johnson OB and V6 Mercury can share props, and that same prop will fit an Alpha 1 drive, with the correct modular hub.
So if the Yamaha prop has a 4-3/4 hub, it should fit a MerCruiser Alpha 1.
