further
- Jun 18, 2009
- 1,034
I've got a 1988 Maxum 17', 1988 85hp force that I just purchased a new michigan wheel prop for. My previous prop was a composite and had an open end and fit well enough for the prop nut and tab washer to be tight. This prop is closed at the end and no place for a tab washer? Whats the deal? So i put on the thrust washer first, then the prop (when I do this the thrust washer actually seats tight into the hub of the prop, but spins freely. Then I have just enough groove on the shaft to put on another washer with tabs that lock into the grooves on the outside, then a washer, then the nut. Does this look right? I was using a composite prop last year (my first boating season) so this is my first experience with an aluminum prop and I'd like to make sure I've got it right. I've attached photos of what i've got.
Thanks for all your help with this.
