does this look as bad to you as it does to me?
lucky7
my brother sent me this picture of his 42' sailboat today, and i am shocked. now he has been an avid sailor for decades, so im sure he knows what he is doing, but boy that ice doesnt look like its doing the hull any favors...
jay_merrill
Re: does this look as bad to you as it does to me?
You forgot the photo!
MRS
There is no photo.
lucky7
it always takes me a few shots to get a photo uploaded, this should work
Ayuh,... It ain't all That bad,...
The shape of the hull allows it to rise as it freezes....
lowkee
At least it won't go anywhere if the dock lines come undone.
Triton II
Wow, thanks Bond-o, I didn't know that as it's not a common problem here.
gss036
Sail boats are pretty tough, I see the ground quite often in the islands here. People will come into an area on high tide and they don't know and the tide will go out, then the boat will be laying on it's side for 5-7 hours until the tide comes back in. I wouldn't worry about it. Usually salt water doesn't freeze that easy so he must be docked in fresh water.
lprizman
free scum line cleaning
Philster
Non-issue.
Pools freeze all the time. The water has plenty of places to go. Like up.
Home Cookin'
I thought you were talking about the 2' of white stuff onthe deck until i enlarged the photo and saw it was the cover. Are you talking about the water? No problem.
Moving ice can cause problems if it's attached to a fitting like a ladder.
aspeck
Personally I would not want that ice around my boat for fear of cracking the hull as the ice continues to expand and shift. However, has been mentioned, sail hulls are tuff and shaped so the boat can rise in the ice.
It might not be an issue and something to worry about, but if it can be avoided, I would ... either take the boat out or attach "ice eaters" around the boat to keep the water moving and from freezing.
lakegeorge
Obviously some of the replies are from people who never lived in Michigan. I don't know where your brother lives, but in Mi. they will bubble the area around their boats.
The ice will crush a hull if it gets thick enough and cold enough. I would never do what he is doing.
stylesabu
Master Chief Petty Officer
if the hull has no place to go then ,yes this could be an issue.if it was free floating and able to rise or lower with water level it would be ok. but if there was build up on the hull and ice/water was able to adhere I would be concerned. had a built in pool in chicago as a kid skatec onin the winter,freeze never damaged pool. did crack a couple of lines(lack of winterizeing) but never damage concrete
