Does rpm limiter on power pack shut a cylinder down?
ba_50
The PP #585260 is on a J48ESLEDC1996 and sometimes both cylinders are firing and sometimes not. The carbs are ok so would it be safe to say it was a PP or would a stator or wiring harness have something to do with it? Pr is a DVA the only way to find out? Thanks.
jonesg
Re: Does rpm limiter on power pack shut a cylinder down?
Do both cylinders misfire or just one particular cyl?
Swapping the coils around would show whether the problem follows the coil.
You can do troubleshooting without a DVA, a timing light is helpfull to see whats firing and whats not.
