I have a 3.7 Mercruiser I/O, it has been sitting up for 5 years, and it would not run when it was put up. I can not get spark, from what I have researched the problem of no spark is very common on the 3.7, and from want I gather it always seems to be something different.
I have already...
change the oil
got the motor turning freely by oiling the cylinders, and removed the valve cover to oil the valves, cam, lifters and etc.
installed a new marine battery
turned the motor over a few times to blow the oil out of the cylinders without the plugs in
unhooked the gas tank from the fuel pump (it is full of old fuel)
as far as ignition goes I...
ran jumper wire from the battery,
tested the coil,
inspected the rotor, points, cap and plugs,
inspected all fuses and wires
now, im going to...
replace the condenser (i read of them going out multiple times on some people)
remove or disable the neutal what ever start switch (temporarily)
check the actual ignition switch(i *think* the purple wire on the coil runs to the ignition switch for keyed power)
then if none of this works,
replace the points, rotor and cap
and when ever i get spark, im going to check/adjust the timing, address the fuel problems and adjust the carb, then move on to the cooling system, and lastly the hydraulics.
any other suggestions, especially with the no spark issue?
I have already...
change the oil
tested the coil,
now, im going to...
