does any one have a trihull or a chrysler boat
Status
Not open for further replies.
i have a 1968 chrysler boat trihull with a 50 hp on it and i was wondering whats the con and pros of a trihull i havent bin on this boat in waves over 1 ft so and its a 14' boat and are chryslers any good and whats the cons and pro of chrysler boats
Mark42
Re: does any one have a trihull or a chrysler boat
A few years back I almost bought a Chrysler boat. It was about 15' traditional hull. I did some research at the time and found the boat was from the 1960's. Back then, Chrysler made some small boats with no stringers. They glassed in a plywood deck and completely foam filled the area under the deck. That made a boat that was very rigid, cut the sound of the water, and made the boat unsinkable. The one I saw was in good condition, but I don't know if the foam was full of water or not. Chrysler was making boats and outboard motors at that time and they were very popular. There are a few websites for collectors of these boats, so there is a following. They must have been made fairly well or there would not be any around today.
Tri hull boats are great for lakes and calmer water areas. I boat on salt water and have never seen one on the bay. They have a reputation for pounding hard in waves, which pretty much keeps them in lakes and rivers. They have the big advantage of being very stable due to the wide bow area, and that makes them popular with fishermen. They generally also have planing hulls, so they pop up on the water quick, stay on plane at slow speeds, and are easy on gas compared to deep V hulls. An easy planing hull is great for water sports like tubing, skiing, etc.
How do you plan on using a boat? If like above, a tri hull would be a nice choice.
the chrylser i boat i use in salt water so ill see whats it liek in rough weather and i boat the boat and the owner before sayed he redid the deck he put in open cell phone and there were no ribs so when i hit the keel coming off the traielr in on a bad ramp i had a hole and the foam absorbed it and now i i dont have a deck and the holes fixed but what am i supose to do with the new deck do i get foam and fill it again and then deck over that or put in ribs and deck over that?
fisherguy123
I just purchased a 70`s era Chrysler Valiant 2 weeks ago that is in great condition. I took it for a ride on an ocean bay here in Newfoundland and the chop was quite light but it rode like a dream and barely leaned when turning at a speed about 30 mph. It is so stable compared to my other "v " hull runabout. I think you can compare the load capacity of my 14 ft tri to a 16 ft v hull. I found a review in popular science of Chrysler Cathedral Hulls which you might find interesting to read ....just google up........1969 chrysler valiant
boat......and pick the book site. by the way the cost of my boat in`69 was $875........I just paid $2000. for boat motor and trailer so it didn`t depreciate in 30 years.!!!!!!!!!!
happy boat hunting!!;)
sublauxation
Had a late 60's 16 footer with the cathedral hull and an 85 hp Chrysler motor. At 30mph in 2 foot rollers it felt really stable,.... but every once in a while you'd hit one wrong and it would just about knock your teeth out and send spray 30 feet out each side. She was super stable out on Green Bay when anchored in some pretty nasty waves.
The boat seemed to be really well built and solid all the way around. We abused it very badly and the boat took every bit of it easily. I'd love to have it back, and I keep an eye out on Craigslist for another.
As far as the floor, try posting in the restoration section.
DaNinja
Our Starcaft is a tri-hull deckboat. We like it, but I don't think I'll ever be bragging about the ride in the LOTO chop.
Bob_VT
Re: cons a pros of trihull
Well.... how about using the search function in this category. There have been hundreds of discussions.
Trihull are nice design if used in the proper water.......used in the wrong conditions and they will deliver a rough ride.
sublauxation
They're super stable when underway or anchored, but can pound you pretty hard when you hit a wave wrong....which will happen frequently. I've had 2 trihulls (one was actually a cathedral hull), but now I have an aluminum V. I do miss the stability of the trihulls, but I don't miss the ride.
If you drive sensibly with the trihull, the ride wont be bad, I just never drove mine sensibly.
DaNinja
Wouldn't have to search beyond the other thread he has on the same page.:D
bullet 101
Had a tri-hull in my younger years and remember it well.As for pros and cons,no pros that i can think of but cons are rough enough ride to make you sterile:eek:
Bob_VT
Merged threads. ;)
tallcanadian
You will find that tri hulls, for the most part, are very rough in choppy water. They will pound the waves rather than cut through. However, they are a very stable boat. You can stand on the sides and they won't move a whole lot. Also when turning they tend to slide over the water instead of tilting or leaning into the water.
sublauxation
I have 3 kids already....so I would have to put sterility in the PRO column.
jimbo_jwc
Ship Happens
Have a 68 Woodson 18' dual cathedral hulls 72 120hp chrysler w/140 that takes 1-3 well with being heavy and deep v . but go fast in big water is pounding no boat,er should be put through .
Status
