does 20hp and 25hp same bore engine?
lost_bone
1984 20 hp johnson does it same bore size and engine cc as 25hp??
does it speed same on both 20 and 25hp on 14' S-14 lund boat?
Chinewalker
Re: does 20hp and 25hp same bore engine?
If you're talking about the same years, then yes, they are the same displacement (31.5 cui.). They should afford similar performance, with the 25 having a little more grunt due to better carburetion...
lost_bone
yes same year.. like 1984 20hp and 25hp
if both same bore then is exhaust same special differnt is carb?
Chinewalker
Yes, the only differences would be in the fuel system. You can confirm by looking at the parts listings at shop2.evinrude.com
