radiocontrolhead
- Feb 5, 2015
- 26
I will hook the engine up to muffs or submerge the lower unit in a tank and will get the same results. A small amount of water will be discharged from the top of the driveshaft house/ below the engine housing but nothing significant. Its on the Port side. It appears at idle that only a trickle will come out and with the engine revving up a bit a little more water will come out as well but not a well defined stream as i've seen in videos.
Is this the pee hole? are these models equipped with them?
thank you
thank you
