The iboats forum moderators are excited to announce that at this time it appears the iboats forums posting pictures function is working once again. Though we cannot promise for how long, we're hoping for indefinitely.
Re: Does 16:1 ratio sound right for a comando 500 outboard?
Can't answer your question but that is one of the best uses of pvc I have seen in a while, very nice.
The one sticker says a pint to a gallon of gas so I would go with that since it is right on the engine, seems like alot but those older engines really liked the oil.
Thanks abf. I like to stand sometimes when I fish and the outriggers make it super stable. They are easy to take off for transporting or for a lazy river outing.
I thought that 1/2 pint per gallon was a little much also but I guess Ill carry a couple spark plugs along just in case.
My 2 aftermarket manuals covering many brands 61-70 all Commandos are 16:1. They use a Tecumseh powerhead.
Manual; covers Commando and the Tecumseh powerhead.Power heads are classed "split crankcase" and "unit block"
You probably know these are air cooled and the leg is not cooled.You can use a good 2 stroke oil or a good TCW3 rated oil.
Thanks steelespike. I took it out yesterday with 16:1 TCW3 and had a couple extra plugs on hand just in case but didnt need them. The motor ran great all day. I could get 6.5 mph on the gps on the canoe pictured above. I knew it was air cooled when I picked it up. I dont like to worry about impellers and water cooling.
Hey, just read this and pulled Grandpa's Commando 550 out of the shed! hasn't run in 30 years, but was drained and stored.
Needs re-furb. Where do I start? got a manual? Would love some help. and be able to take my wife and daughter out Scalloping July 1st in the Gulf!
Rob: you can use TC-W3 oil or chainsaw oil. Is there some mystery involved in the very clear (to me) instructions? They do say exactly: "16:1 with outboard oil".
