Hello people,<br /><br />Tomorrow I have to winterize the boat (part of the marina is already frozen!) .. haven't driven it in a few weeks, and the engine doesn't like to come back on.<br /><br />(Engine is a 1979 v4 seahorse 2stroke Johnson 85hp)<br /><br />When trying to start normally, it might cough a few times, but no real running. Battery doesn't last long this way either!<br /><br />Then I tried it with starting spray (I know, it's bad for the engine, no oil in it). Sprayed it past the choke butterflies. The engine then tries to fire up immediately! Except.. it doesn't last long Just a few seconds.<br /><br />The kicker is, if I move the warm-up lever up and down very fast the engine will keep running, faster than idle, not too confident, but it will keep running. When I stop doing that (I eventually want to move it into gear and start going it stalls again.<br /><br />Sooo.. fuel delivery problem? Where should I check? Carbs? Take them off and make sure they're ok? Any tips for tuning carbs (I am not sure what settings to use).<br /><br />The engine has always worked, although starting it never liked and idling it doesnt like either (stalls and/or wets plugs). Once up and running at a load though it has never given any problems (not even when we bounced over a submerged rock, skeg took a hit, prop didn't, long and different story, the sound of the impact you'll never forget! <br /><br />Then once the boat is on land I'll have all the time in the world to disassemble parts and with help of the massive collective knowledge here hopefully turn it into a reliable next-season engine I just have to get it to another harbour (about 2 nm) tomorrow!<br /><br />Thanks for any help!
