BUHurricane
- May 16, 2009
- 16
When I got the boat out this year, i noticed the dock lights arent working. The switch does not light up. Everything else on the panel works and the 1 fuse that i believe is used for the whole panel is fine (it is located at the battery).
The bulbs are not blown and the connections to the light and the connection to the switch are all intact.
There are breaker switches for each device, and when i reset the docking lights, it does not change anything.
Do you think the switch is bad? and if so, do i just need to replace it and not worry about the breakers?
Also, would the switch still light up if there was a problem somewhere along the wires going to the lights? if so, it leads me to believe it has to be the switch.
Thanks in advance
Thanks in advance
