1995 Mercruiser Bravo 3
When I turn right and left, my outdrive does the classic grinding noise.
I took out the outdrive, there was some water in the u-joint bellow, and the u-joints where covered in water.
The gimbal bearing seemed brand new, smooth & no play. I changed it anyway.
So, it seems gimbal bearing is fine, does it mean the u-joints are not good?
How can i tell if they are good/bad ?
I have attached some pics to this post, so you can see how they look.
If the u-joints do need to be changed, how is that done?
Thanks!
Thanks!
