brettjbyers
- Jun 12, 2012
- 1
My father has a lift with a 110 motor plugged into a three-prong outlet. It was moved to a new location without easy access to an outlet.
This thread http://forums.iboats.com/showthread.php?t=471529 discusses some options on how to setup a solar kit with battery but the piece I am uncertain about is if I can take a motor with a 110 three-prong outlet and use an adapter to plug into a battery (which would be charged via solar). The Marina is saying we need to change the motor since there is now where to plug into the battery. Surely there there is a way to go from three-prong outlet to pigtails to hook into the battery, so is this an issue of converting power which I clearly don't know anything about? Does he really need to switch out his motor for a 12v motor?
If the boat lift motor really would need to be changed, I had one other crazy idea. You know those recharagable batteries you use to jump start your car or inflate water toys? We have a couple with an outline on it. Could the lift be plugged into that over the weekend (up and down a couple times) then re-charge the battery during the week, or would one raise or lower kill that battery? I don't have a sense how much power is needed.
Thanks everyone
Boating (and power) Novice.
Thanks everyone
