moneypit73
Thread starter- Joined
- Jul 25, 2003
- 4
I bought a used boat to fix up. It is a 73 johnson 115. Have replaced ignition switch, solenoid, starter, coils and have new battery. The problem is i turn the key and i get nothing not even a grunt. Can cross out the solenoid and it cranks. Think there is power to ignition switch because my choke is working. Also can use 12 volt light tester on ignition points and it seems to work. Could it be the power pack? If not do u have any other suggestions? Thank you
