Re: Do I need fresh water cooling
Let's get our terminology straight...<br /><br />Freshwater cooling generally refers to cooling systems that circulate raw, sea, fresh...(whatever type of water your boat happens to be floating in) throughout the engine and exhaust manifolds.<br /><br />Closed cooling systems circulate antifreeze through the engine. Cooling takes place via a heat exchanger and the exhaust manifolds that have raw, sea, fresh...whatever...water flowing through them. The heat exchanger works much like an automotive radiator that uses the air flowing through it to cool the antifreeze.<br /><br />If it were me...I'd opt for a closed cooling system if my boat were to be used the majority of the time in brackish or salt water. <br /><br />Although it would be wise to flush the raw water components of a closed cooling system after the boat was used in salty water...it's not critical. Nevertheless...doing so will add more life to those components. Flushing is a simple process...and well worth the minor effort.<br /><br />Walt
