I have a 1999 Bryant 182 Limited (dry weight, 2500 lbs), Mercruiser 4.3 liter V6 with Apha 1 Gen 2 outdrive. Currently running an aluminum Turning Point prop, 4-blade, 19 pitch. The outdrive has 2.0 on it, indicating it has the 2:1 ratio, meaning it was originally sold in a high-altitude area (that's what that indicates, right?) Unfortunately, I can't confirm that it is actually a 2:1 ratio - the boat was a mess when I got it almost 4 years ago - kinda cobbled together, including throttle controls for an outboard modified to run the 4.3 Merc.
Anyway, finally was able to do some WOT runs yesterday, and wanted to get your feedback on the reults. At WOT, all it could muster was 42 mph (gps) at 4050 rpm (holeshot seemed fine, btw). Am I over-propped and bogging the engine, since I can"t reach 4400-4800 rpm at WOT? I figured I would need a higher pitch prop, since I'm running a 2:1 outrrive, but the results seem (to me) to indicate otherwise.
Any advice would be gretly appreciated. Thanks!
