Re: DIY Shrink wrap - pros & cons
there are vents u can install to address the moisture issue. other than that i found it to be too expensive. i suppose if the kits were well built & u could reuse them every year it may be cost effective. even so, u will still need to buy the wrap every yr. plus your time & labor to do it. i'd rather spend the $$$$ on a good cover. remember also that once u wrap your boat u can't access your boat without cutting into the shrink wrap.
