Hey guys, I am pretty experienced, but very weirry of drilling out a busted s.s. waterpump bolt on a 1990 70hp yamaha, which has very low hours.....this is a its first water pump change, and it has seen nothing but fresh water........only replacing it cause the temp sensor goes off at idle, and its squirting was lower than normal at idle...raise the idle and the buzzer goes off and the water flows well........I am doing everything by the book.....I learned along time ago, that s.s. fasteners and aluminum dont work well.. They get very gummy, when it comes to removing.....well low and behold , i lube the hell out of all or them, worked them all out, but this one snapped at the beginning of the thread, and i cant seem too remove the seal housing, which is cast iron....and ideas or can a water pump run on 3 new bolts?
