Re: Distributor question Delco EST
I have no idea what the specs are for Marine Power engine, that's kind of a problem with gettintg an engine package that isn't OEM, basic informtation is not out there for anyone but the dealers. no manual or anything. There are also few dealers that can help.
Below are the specs I found for a Volvo Penta using the EST distributor. Look at this advance chart.
5.7GL-B/C/D/E Models1
Engine RPM. . . . . . . . . . . . . . . . . . . 89 AKI Fuel
Initial . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12?
600 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 21?
800 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 24?
1200 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 27?
1600 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 28?
2000 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 29?
2400 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 30?
2800 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 30?
4000 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 30?
4800 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 30?
Now, you are not seeing even 12? of advance if you read it right. Initial timing is set with the distributor in base timing mode. When out of base timing, you should see around 21? at 600 rpm (not 12, forget that number, it's only used for setting the distributor for base timing) then at 30? you are at max advance, right where you should be.
If you are getting a backfire at WOT and your advance is close to the above, then you have a lean fuel mixture. probably not what you want to hear, but that is your problem.
