Re: Distributor for AQ131D
I don't know if that helps, but thank you. The Seloc manual lists a Bosch JF4 for the AQ125A and B. It also lists the JF4 for the AQ131A. My manual doesn't list anything for the AQ131D. I have the opportunity to get a used AQ125A Bosch distributer thats in better shape than mine..but didn't want to spend the money if it wouldn't fit. (BTW..Stupid me again...my existing distributer is ok but I busted off one of the screws that holds the cap on. Then I tried to used a tap, which I then busted off in the hole! Right now I only have one screw holding the cap down!)
