Distributor advance
Rich Novak
72 225 omc sterndrive
What effect does to much or to little advance have on RPM.
My problem is engine acts like it is now getting fuel surges .
New fuel pump, rebuilt carb, advance set about 22*
Thanks, Rich
fuel surges are exactly that, fuel surges. my guess is dirt in the carb yet, and the float not set right.
advance is governed off of RPM by weights and springs. too much advance and the motor starts to suffer from pre-ignition. too little advance and your simply low on power.
Rich Novak
Thanks, Rich
Rebuilt carb recent . is 22* advance enough??
It doesn't want to go more than idle
Thanks, Rich
bruceb58
Thanks, Rich
I am assuming 22? is your total advance(base plus centrifugal). Total should be closer to 30?. It also is going to make no difference with your problem going past idle.
I would be checking your fuel pump pressure with a gauge, checking compression and verifying your firing order is correct. I am assuming points ignition...did you set dwell with a dwell meter?
Rich Novak
New fuel pump.electronic conversion of points. Compression good, nwrw heads with valves.
Of advance should be around 30 total I need to increase it.
Why wouldn't effect RPM. ??
bruceb58
If you can't get past idle, your distributor hasn't even started advancing.
Has your engine ever run correctly since you put in the Pertronix module?
I asked a couple other questions in my previous post.
your distributor will have about 22 degrees of mechanical advance. total advance should be base + mechanical or 8 degrees base + 22 mechanical advance for total of 30 degrees by 2800 RPM
if you cant get past idle you have a fuel problem or some other problem. if you didnt chase each and every passage with a wire and compressed air, its not clean.
gm280
When you say you can't get beyond idle, why not? Does the engine start breaking up or starts dying, or is there an actual mechanical problem stopping it from moving? Have you verified TDC on number one cylinder is actually TDC with the pointer that you use to set initial timing? :noidea:
Rich Novak
When accelerating the engine surges( higt low high low) like it is running out of fuel wants to die. Starts up easily. Timing is dead on 10* #1 on tdc.
The reason I keep going to timing adv is it was gunked up I took it apart and cleaned it now I don't know if I have it set correctly.
I am going to install a fuel pressure gauge today ,read somewhere pressure should be around 3#.
No other mechanical problems that I am aware of to hold it back.
Thanks, Rich
Ayuh,.... Carbs need 4 to 6 psi,....
gm280
Rich, you don't have to install a fuel pressure gauge in the system. Just put one on the end of the fuel line that goes to the carb and crank the engine. Even if it starts (with fuel in the carb), you will read the typical pressure and can see what the fuel pump is doing. A real simple quick look. I know this works well because I just did that about a week ago myself on an engine. It read 4lbs steady. So you can figure out if the fuel pump has issues real quick. :noidea: JMHO!
Rich Novak
Thanks, I will try that Tues.
bruceb58
No, you need it in there while the engine is running. Its not just the fuel pump pressure at idle you are testing, its fuel pump pressure when it needs to be providing more flow.
It may not even be the fuel pump, it may be the anti siphon valve at the tank but you need to measure the pressure while you are trying to run the engine after idle.
Rich Novak
Oh ok thanks
