I know this is an older post, but for anyone still checking it out,
Great points from everyone here! When adjusting the distance between the coupler and winch stand, making sure you have the right tongue weight is key. Aiming for around 10-15% of your total trailer weight on the tongue usually helps with stability and prevents sway. If you’re too light on the tongue, you’ll definitely notice sway, especially at higher speeds.
If you need to move your winch stand to adjust the weight balance, just keep an eye on how your boat sits on the bunks. And like others mentioned, if the weight is still off, adjusting the axles can make a big difference without shifting the boat too far forward.
Hope that helps anyone setting up their trailer!
