I have run into a situation where a foam core in my 24' Reinell is waterlogged due to improper sealing of the holes used to inject the original material. The foam appears to be about 16" X 36" located on the starboard side in the engine compartment. Could that amount of water cause the boat to not trim properly? I know that it needs to come out of there else the r-o-t will be soon to follow into the exposed endgrain plywood. I have heard that acetone can be used to dissolve the foam which then can be "drained" through a hole that I have yet to drill. I would rather not remove any flooring as the season is just getting underway, but I would like to get rid of the water ASAP. Any helpful advice is appreciated.<br /><br />Regards,<br /><br />Mark Libby<br />iboats user: rml
