Discrimination...
Rotti
Thanks for consistently ignoring all my threads, folks! Is it because Im from Germany or what? Every ****ty posting in here gets at least a couple of more or less stupid answers- mine do not. Unfortunatly I dont know how to delete my older postings but if the guy whos running this is at least reading this thread here: Please remove everything fom me and erase my name and login from this board- Im done and will not bother your all-american forum any longer! <br />Long live "homeland- security"- by the way: weve had something similar over here a couple of decades ago- you guys should know better.....<br />With final greetings,<br />Rotty
Spidybot
Re: Discrimination...
Guten Tag, Rotti! <br /><br />I'm not sure I understand your problem? Your country of origin has nothing to do with the amount of responses you get - you may however experience a lack of interest when you refer to German stuff as the majority of members are American.<br /><br />I'm surprised nobody started out by recommending you got yourself a manual. <br /><br />You should read this post: http://www.iboats.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=17;t=009035 <br /><br />A quick browse through your posts makes it clear, that many have tried to help you:<br /><br />Topic: Honda B100L 10hp cooling-water? <br />You don't state any specific ID - makes it hard to comment on it. On the moved post you get responses.<br /><br />Topic: OB placement at transom? <br />You got an answer - the problem has been discussed in detail here many times and the basics really are basic (covered in any manual and in detail in specialist material - you're welcome to get the free booklet on my homepage).<br />Do a search on the forum for 'mounting height' or x-dimension. <br /><br />Topic: Manual Tilt on 40hp Evinrude VRO <br />Again you don't state enough specific data to really let anybody give you a meangingful answer<br />Suppose posting the same topic twice was a mistake?<br /><br />Topic: To VRO or Not VRO... <br />Got plenty answers. A search on the forum for 'VRO' would return enough reading for one whole day.<br /><br />Topic: Evinrude 40hp VRO manual tilt again- nobody know´s something?! <br />Plenty of response - especially when you get your info together and state he motor ID<br /><br />Topic: fuel mixture ratio for 1969 Johnson 33hp? <br />Got one correct answer<br /><br />Topic: Chrysler 700 skier vs. Johnson 70hp? <br />You got the clearest answer - the same a thorought search on the forum would have produced.<br /><br />Topic: Conversion Suzuki DT6 to DT8? <br />You got an answer from a real specialist. Again a search on the forum would return plenty of oppinions.<br /><br />Topic: Honda BF50 gear ratio's <br />Even though this forum is not a trading place, you got replies to most of your (numerous) questions.<br /><br />Topic: Honda B100L 10hp lower-unit <br />Again, you got an answer<br /><br />Topic: Year of 35hp Honda? Lower-unit wanted!!! and c: ... again 35hp, forgot something: <br />Still: This is not a trading place. And use the EDIT function instead og starting a new post to add info to an exisiting.<br /><br />Topic: URGENT- need info on Honda 35hp, please! <br />You got an answer, exactly the one you were looking for<br /><br />Topic: Converting Honda BF35 to BF45 <br />Another case where a search would enlighten you. This has been up on plenty occasions.<br /><br />Can't see other than you get a good deal of benefit from this site so you've got no reason for feeling let down.<br /><br />PS! If you think it makes a difference, remove the Germany-info from your profile,
JB
Thanks, UU. Excellent post..<br /><br />Rotti, I don't think it matters to anyone here that you are in Germany.<br /><br />You are getting answers to your posts that are clear and provide enough information.<br /><br />This might help a bit. Check it out.<br /><br /> http://www.iboats.com/cgi-bin/ubb/ultimatebb.cgi?ubb=get_topic;f=17;t=009035 <br /><br />Moving to NTDWB<br /><br />Good luck. :)
