Re: disconnect oil injection ?
Originally posted by ivar:<br /> The Yamaha oil injection systems seems very reliable. what motor is it? <br /><br />Not sure of the gap for the 25hp, but most any other Yamaha uses 1mm (or 0.039")
I disconnected it because the oil cutoff was makeing the engine quit , My test was ,disconnect the Oil injection tube . Leave the Oil in the reservoir , And the sensor in the head hooked up and see if it still cut's off , And it does not , I am not a really particular type , And I am self employed . So I have precious summer here , And it works this way , And I don't want to miss a few trips, if its fine till the summer rush is over ,then I will have reasonable turn around time at a repair shop . then I will take it in ,But I hope to run it for a few day's .
