Disconecting VRO
seabird
I would like to disconect the VRO unit on my 1987 225hp Johnson and would like any info on going about this. Thank you very much for any input you may have on going about doing this.
Dhadley
Re: Disconecting VRO
Just pull off the oil feed line from the tank and cap the nipple on the pump. Disconnect any alarm wiring. Great motor.<br />Good luck!
Frank
Mix the oil in the gas before disconnecting the VRO. Run engine long enough to burn the gas in the carbs and fuel line. Now disconnect.
