MajBach
- Jun 21, 2003
- 564
Hi again. I have a Faria tachometer that's been giving me trouble. Last year it started sticking at a low rpm - a little bump to the glass would dislodge it. This year, it's stuck pretty tight. I contacted Faria and they said it is no longer in stock but it is serviceable. Rather than send them a cheque for $35 and pay the same for shipping AND have to wait 8 weeks (standard turn-arond time) for them to fix it plus the delay crossing the border, I'd like to fix it myself.<br />I have it off the boat and in front of me. There are four long brass bolts protruding from the back, each held to the casing by a nut. When I loosen these nuts, the bolts become 'wobbly' and I can feel the contents inside free to move. Obvioulsy this is the first step in disassembling it. But, I can't get any further. It would appear the casing 'breaks' apart from the front. I would imagine one bolt holds the needle, one the face, etc. Problem is, I cannot figure how to get under the glass. There is a nice brass ring on the circumferance of the glass that holds the glass down - on the underside of the ring is a lip that is bent over 90 ° such that it appears to hold the plastic housing together. The brass ring will rotate freely but is not threaded. <br />Can this ring be removed? Do I need to? Is it possible to spray the insides with a lubricant that might coat the sticky needle?<br />One more thing, when I loosened the bolts, the needle freed up, but not without a bit of vibration. I re-installed the tach and started the motor. the tach moved properly but the sticky part is still noticeable. I dont think this thing is garbage just yet but I need the next step.<br />Thanks for taking the time to read.<br />Randy
