CaptainPuget
- Sep 29, 2002
- 137
I have a 1987 Johnson 110hp that has had its VRO system disabled. The engine is running fine at mid and high speed. Actually it runs OK at low speed as well but it just seems to run "dirty" at low speed. By that I mean it smokes, the exhaust smells of unburned fuel and it leaves a sheen of oil on top of the water at idle. The plugs are always black and wet when I check them. I have rebuilt the carbs and changed the thermostats and checked that it is running at the correct temperature. No help. There is no low speed adjustment on the carbs so I cannot lean it out at idle.<br /><br />Could this condition be a result of running 50 to 1 fuel/oil mixture in a machine that was designed for something around 150 to 1 at idle speeds? If so is there something that can be done to the carbs to compensate? Has anyone else experienced something similar on a disabled VRO system?
